~*77*~ Xenophobe
Joined: 08 Apr 2003 Posts: 10466 Location: Sshh... I'm Hiding
Posted: Fri, 06 Oct 2006 22:24:20 Post Subject: |
knight0334 Rated XXX
Joined: 22 Aug 2003 Posts: 2234 Location: Neither Here, Nor There
stimpy Rated PG
Posted: Tue, 17 Oct 2006 20:31:58 Post Subject: |
Hi - welcome aboard. I appreciate the tip on the bass and treble controls! I will have to try that if I ever re-install this! (I sold the car it was in, but kept the radio). And get this, the manufacturer apparently doesn't even know about that... They suggested that I just turn the "loud" button to off!  |
tronixinc Rated PG
Posted: Thu, 19 Oct 2006 06:24:20 Post Subject: |
Yeah - the TV tuner is for TV audio as far as I could figure. The antenna actually involves two unique plugs, as seen in this picture... LINK
See the lead with the blue label marked "TV". I didn't know what to connect to it, and pulled in no signal without an antenna.
There is a mode I could access where it lets you tune through over the air TV, but I never got a picture or audio, but it went untested really... |
dogga-20v-turbo Rated PG
gobanjoboy Rated PG
Posted: Mon, 30 Oct 2006 02:48:28 Post Subject: |
I ordered the Red Power In Dash Radio/DVD/CD/MP3/MP4 Player from geeks.com. They sent me the Explosound In-Dash DVD/AM/FM/MP3/MP4 Player. I got it installed. Seems to be the same as the Red Power. The TV tuner is for both video and audio. It would be my guess that whoever installed your deck hooked it up to the emergency brake sensor. I believe that if your brake is not on the video won't work.
QUOTE FROM GEEKS.COM - http://www.geeks.com/details.asp?invtid=990DVD-4
"WARNING: In most states it is illegal to have a video monitor operating in plain sight of the driver while the vehicle is in motion. Many manufacturers include a wire in the monitor that must be attached either to the emergency brake or to the gear selector sensor. In this case, the in-dash monitor will not operate unless the vehicle is stopped and the emergency brake is applied. Whether or not such a wire is included, we strongly recommend that the vehicle not be operated with the in-dash monitor in use."
