swank1 Rated PG-13
Posted: Sat, 31 Dec 2005 01:54:16 Post Subject: |
And for those who have always wondered what was inside a thumb drive... Or in case you were curious about the dab of glue holding these together... Check out the attached image.  |
kabammi Rated PG
redders Rated PG
Posted: Sat, 27 Jan 2007 08:09:09 Post Subject: |
This experement really interested me! Just a real shame it doesn't seem to work under windows, I'd really like to build a USB HDD RAID array using a few 500GB WD MyBooks, I suppose it could be done using a few of these IDE to USB convertors: http://www.neutronexpress.com/prod.cfm/499470/ADDONICS/ADIDEU2/IDE_TO_USB_2.0_CONVERTER
but that would miss the point, Google doesn't seem to show any solutions allow USB RAID Arrays... Has anyone had any more luck with this?
P.S.
I've seen those damn USB drives before! My college supplies them to students for £5 ($10ish) claiming their value to be around £12 ($24) and the damn things are only 128MB! Can get a higher capacity MP3 Player for £5, oh, and they also have the same problem with coming loose and failing a lot. |
Enigmachine Rated NC-17
Posted: Sat, 27 Jan 2007 12:18:10 Post Subject: |
Hey good timing!
I was just going to try to do this thing using SD cards & thumb drives under FreeNAS. Looks like it would probably work, but it's no more stable than the weakest part... Thanks for trying it out!
I wonder where I could find a source of free 128 meg drives, I bet some people are throwing them out these days... Plug in 127 of them and you get a 16 gig array! As a nice side effect, you might also get pretty x-mas lights that blink as you access your striped files.
redders, I just plugged in a OCZ Rally thumb drive in my FreeNAS and it detected it right away, all I would need to do now is to reformat the drive in raid format and I could add it to a RAID array. Looks like FreeNAS supports all kinds of USB drives (Flash drives, HDDs, CF cards) without any problems as part of RAID arrays, probably many others systems do too. You can boot FreeNAS off thumb drives and others so you might not even need to create a new partition on your current machine to try it out. |
x.gardner Rated PG
Posted: Wed, 13 Aug 2008 20:49:08 Post Subject: |
I am not sure... I am looking at the one traditional hard drive I have connected via USB and it has more options than the one flash drive I have connected. Can't try RAID or anything since it is just one, but the flash drive has everything grayed out now, and the hard drive just has "extend" grayed out. This is now Vista, and not XP like in the test I did, too.
Was looking around recently to try doing this experiment again... Not sure I could do it any better, even though I do have better flash drives.
Would be cool to make these 16GB of chicklets work together in RAID:
