Joined: 07 Apr 2003 Posts: 20352 Location: New Jersey
Steven Tarise Rated PG
Pipoloko Rated PG
Posted: Thu, 03 Nov 2005 05:20:24 Post Subject: |
Hi to all,
I have a Gforce 6600GT 128MB AGP and my doubt is if it will be possible to install that cooler on my videocard ?
Taking into account the manufacturer specifications seems to be only compatible with 6600GT PCI-EXPRESS and the only one in AGP mode is 5700 FX i think.
The holes where I have to lock the heatsink are the same as the PCI-EXPRESS model. Im adding a screenshot to let you see a more clearly view, the only that changes in respect to my card is the heatsink, my heatsink is diferent than the old one, is smaller and fully silver, I think is the new heatsink that uses XFX for the new 6600GT AGP. Another think is the heatsink of the memory, maybe it will be a problem to fit Artic cooling NV Silencer 6, but, can I remove it to install that cooler? or this will make an excessive rise in temp over the memory module?
Pipoloko Rated PG
Posted: Mon, 07 Nov 2005 05:12:24 Post Subject: |
Hi
Yes totally agree with you, seems to be imposible to fit this cooler on my videocard, If it was possible I can imagin pushing my card beyond his limits, anyway it's not possible
I decided to look for a Zalman VF700-CU wich has a best fitting solution for my card, maybe it not exahust hot air outside the case, but sure that is a better cooling solution than the stock fan. |
Falcon Rated PG
Joined: 16 Nov 2005 Posts: 2 Location: Göteborg, Sweden
Posted: Wed, 16 Nov 2005 17:31:24 Post Subject: Great work! |
Great review!!! and hopefully you will update the review, the info on 2 slot gaps on certain MoBos, to make it an outstanding review btw, it seems that this review is the only decent review of AC NV silencer 6 in english - been on the search for this kind of review and the info the review provided.
If it wouldn't be for you guys, and the info provided by Steven Tarise, I would have dropped the dreams of an AC GPU cooling into my SLI system. Just have to wait for the next salary @ the end of the month and make my dream come true - a silent and cool SLI system (2*ASUS EN6600GT TOP GPUs on an ASUS A8N-SLI Deluxe MoBo)
Thx again and happy greetings from the other side of the atlantic...
/Falcon _________________ Worrying about tomorrow, is paying mortage of a loan you haven't taken yet... (sry for my bad translation )
/Falcon |
Asylum Joshzilla
Joined: 03 Feb 2005 Posts: 1142 Location: Suburbs of BFE
Posted: Wed, 16 Nov 2005 20:10:00 Post Subject: |
Thanks for the feedback!!! Glad I could help.  |
