		| Author | Message |
		| Doctor Feelgood Arrrrghh!
				|  Posted: Mon, 21 Feb 2005 08:04:36    Post Subject: AC Ryan RyanPower2 550W PSU |     |
				| |  | This is my first modular designed power supply and I will now have a hard time going back to a power supply that has cables permanently attached. The AC Ryan Ryanpower2 550 Watt power supply is an extremely well built, tightly regulated, and nice looking device with plenty of futureproof features. - The Review |
 Last edited by Doctor Feelgood on Sat, 29 Apr 2006 09:00:19; edited 1 time in total
		| Back to top |  |
		| Little Bruin Boo Boo
		| johan.67 Rated PG
		| Back to top |  |
		| Spire Hall Pass B!tch!!!
		| Back to top |  |
		| JimBowy Moderator
		| Back to top |  |
		| johan.67 Rated PG
				|  Posted: Mon, 28 Feb 2005 09:12:41    Post Subject: |     |
				|  	  | Spire wrote: |  	  | The Ryanpower2 is no more noisy than my 600 watt Noisetaker.  Come to think about it, I don't think I have ever heard it!!! |
 In that case, this psu could be the perfect one for me : powerful, modular, stable, silent and not to expensive. The only unknown factor of course is the reliability of this psu, as Acryan is fairly new to the market.
 PS : about the short/ backward hard drive cable, could it be this "drive" cable is more suited for optical drives (CD/DVD) then for HDD's (sata-based in future anyhow), thus explaining the relative shortness of it.
		| Back to top |  |
				|  Posted: Mon, 28 Feb 2005 09:17:04    Post Subject: |     |
				|  	  | JimBowy wrote: |  	  | its almost time we start using a device to measure the loudness of psus |
 I have access to sound meters, anyone else?  Maybe I will start on any component that makes noise...
		| Back to top |  |
		| Hellfire Rated XXX
		| Back to top |  |
		| johan.67 Rated PG
				|  Posted: Mon, 28 Feb 2005 13:28:34    Post Subject: |     |
				| Read this at their website http://www.acryan.com/index.shtml :
 " The Ryanpower2 is a moddable power supply. Not only you can change the cables but also the fans inside the power supply with ease. Other power supplies use 2-pin fan connectors inside their power supply; that means no easy fan changing! AC Ryan thinks of 3-PIN FAN CONNECTORS inside the power supply to make your life easier when it comes down to changing a PSU fan. "
 Did you notice this Spire, when you took a look inside ? This seems like an nice bonus, if one is modding for silence and/or light effects, provided that these 3-pin connectors are easy to access.
 By the way, does anyone find the inside of this Ryanpower2 to look familiar with any other type/brand of psu ?
		| Back to top |  |
		| Back to top |  |
		| FOX I <3 Quail
		| Back to top |  |
