Joined: 07 Apr 2003 Posts: 20352 Location: New Jersey
Posted: Sun, 13 Feb 2005 11:41:30 Post Subject: Arctic Cooling Silentium T2 ATX Case
Out back you will get your first glimpse of what makes this case unique. While at the top of the case you see two fan grills, this is not for the power supply. If you look closely, you will notice the plug for the power supply is at the bottom of the case, but there are no fans down there. This is because the power supply is not at the back of the case, but rather at the front. - The Review
Last edited by Doctor Feelgood on Tue, 02 May 2006 16:45:56; edited 1 time in total
I just don`t get manufacturers why they still use 80mm fans and not 92 or even better 120mm cuz they are more quiet than those small 80` and not even to mention better air flow with less noise...
but they are restricted by the form factor there is only so much you can do to improve airflow on a pre-desgined form factor. i personally like 80mm i hav e a chieftec matrix with 5 fan ports on it and i like having control of wich go where and how fast they go. _________________ Ignore this^^
Oh come on... there are a lot of case`s which have 120mm fans "integrated" ... so thats not a big problem to solve right? If you like noisey case be my guest and use 5 80mm fans...
fanbus helps with the noise part. and i like being able to configure with fans need more power/noise. 120's are great but i personally like 80's _________________ Ignore this^^
