ZOOZ ZSE29 Z-Wave Plus S2 Outdoor Motion Sensor
https://bigbruin.com/content/zooz-zse29_1
Post new topic   Reply to topic    Bigbruin.com Forum Index -> Home Automation
PostPosted: Wed, 24 Feb 2021 10:56:04    Post Subject: ZOOZ ZSE29 Z-Wave Plus S2 Outdoor Motion Sensor Reply with quote View Single Post
The ZOOZ ZSE29 is an interesting product. As a motion sensor and a SmartThings device it definitely works very well, but determining how appropriate it is to use this outdoors will have to be seen after some time installed exposed to the elements. My gut tells me that the physical design and the stipulations that this outdoor rated device has to avoid heat, sunlight, humidity, and wetness may lead to a fairly short usable life.
Post new topic   Reply to topic    Bigbruin.com Forum Index -> Home Automation All times are GMT - 4 Hours
