Posted: Fri, 09 May 2003 09:11:37 Post Subject: Enlight 420 Watt Dual Fan Power Supply |
Check out the BigBruin.Com review: **Here**
And share your comments / questions in this thread...
Last edited by Doctor Feelgood on Sat, 29 Apr 2006 08:34:45; edited 2 times in total |
rei_iii Rated PG
rei_iii Rated PG
Posted: Sat, 10 May 2003 18:36:52 Post Subject: |
rei_iii wrote: | Thanks.
Also, the fan connector on the Enlight 420W is meant to connect to your motherboard so that you can monitor the rpm of the fan (don't whether its the back fan or the inside fan). The fan conntor does not draw any power. |
OK... so it does speed sensing only, and no power? It had two wires so I assumed it was for power only... I guess it makes sense now that I know it works even when disconnected, but they could have run just one wire and it would have been obvious it was only a speed sensing lead. I do like this idea better than the Enermax I had where the one fan was powered and controlled by the 3 pin lead... Seemed stupid that you had to go outside the psu to power a fan inside it...
Thanks! |
Oh Buh Rated NC-17
Joined: 10 Apr 2003 Posts: 141 Location: Butter Churning Station #3
Posted: Tue, 13 May 2003 09:46:15 Post Subject: |
I hate that...two wires...what the funk! Ohhhhh buhhhhh
So Rei are you sexy?  |
bk Rated PG
Posted: Tue, 01 Jul 2003 01:28:44 Post Subject: |
Hey Big Bruin. Know this is a long time since you asked (but I only read this review today when I was trying to find out about Enlight's PSUs) but the text translated from portugeuse on altavista to:
I found one review with one versao OEM of the same source thermaltake 420w. http://www.bigbruin.com/html/enlight_420w_power_supply_revi.htm it only proves the quality of the same one. questao of the price in Brazil, nao cost to say, is proportional to the weight (about 3 kg).
In case you were still curious. |
