Posted: Sun, 03 Oct 2004 11:01:24 Post Subject: Logisys Glacier Dual LED Fan 500W Power Supply |
 | The silver control knob on the back of the Logisys Glacier power supply controls the speed of the two fans... Unfortunately the control knob was not very reliable; it only worked for about an hour. During that hour, I was able to adjust the speed of the fans (and the brightness of the fan LEDs). Shortly thereafter, I needed to leave the room so I turned the fans down to the middle speed. When I came back, the fans were off... - The Review |
Last edited by Doctor Feelgood on Sat, 29 Apr 2006 09:00:48; edited 1 time in total |
BonusMinutes Rated PG
Posted: Wed, 06 Oct 2004 08:13:43 Post Subject: |
Regarding the 3.3V line... you are very correct, that is bad! I apologize for not noticing as I edited / formated this review, but Hellfire, would you mind busting out the multimeter and rechecking that value?
If it is that high, please let us know (and then get that unit out of your computer ). |
BeerCheeze *hick*
Posted: Thu, 07 Oct 2004 13:20:40 Post Subject: |
I appreciate the great follow-up guys. Didn't want to see Hellfires gear get damaged. Good to see that the 3.3V rail is operating within spec now, although it is at the max allowable. I've included a link to the ATX12V v2.01 design guide for future reference. You may want to use Motherboard Monitor or similar software to keep an eye on things for the next few weeks just to be safe. Thanks.
Formfactors.Org |
