![](images/avatars/gallery/Pop/Dr_Feelgood.jpg)
![](templates/subSilver/images/spacer.gif) |
Tau Rated PG-13
~*77*~ Xenophobe
![](images/avatars/Uploaded/14949972394bf167af63130.png)
Joined: 08 Apr 2003 Posts: 10466 Location: Sshh... I'm Hiding
Posted: Tue, 01 May 2007 13:34:48 Post Subject: |
Tau Rated PG-13
Stefano Rated PG
Posted: Sat, 12 May 2007 09:06:46 Post Subject: |
Hi - the jumper on the review sample was pre-installed to cap it at SATA 150 speeds. If you need to install the jumper, it should look like this:
http://www.bigbruin.com/2007/imageview.php?item=momentus7200&file=pic3.jpg
For SATA 300 speed, just remove the jumper completely.
I am now using this drive on a system that has a SATA 150 controller, but I left the jumper removed, and it is working fine.
NCQ should be automatic... as far as I know. |
Stefano Rated PG
Posted: Sat, 12 May 2007 09:46:03 Post Subject: |
Ok, thanks for the anwser!
Concerning the NCQ, no it isn't:
http://www.sata-io.org wrote: | NCQ is designed into the Serial ATA interface but not all solutions have integrated it. To take advantage of Native Command Queuing it is necessary that both the host controller/chipset and hard drive support the feature. |
Now the problem is to discover whether my laptop supports it or not, and it's always a big challenge to discover this kind of details for laptops! |
Rich Schulthess Rated PG
