dwalden Rated PG-13
DragonMaster Rated NC-17
Posted: Tue, 06 Jun 2006 17:36:14 Post Subject: |
Not al drivers make it available. If you use eVGA's modified drivers instead of nVidia's, it might be a reason. You can just use the real ones if you don't. Then, if the sliders still aren't there, you can get RivaTuner right here : http://www.guru3d.com/rivatuner/ |
dwalden Rated PG-13
dwalden Rated PG-13
Blue|Fusion Rated XXX
Joined: 30 May 2005 Posts: 441 Location: Cleveland, OH
Posted: Wed, 07 Jun 2006 00:47:04 Post Subject: |
Use a third-party program for monitoring the temps. I got all my temps right on my desktop, even HDD temps . I don't know of any Windows apps off hand, however.
Also, heed warning that the CoolBits feature not only just overclocks your video card, but to do so, it modifies the card'ss BIOS. If these get screwed up, you're SOL if you try to get support for it or try to RMA it. _________________ 5 home-built PCs, ASUS A6Jc Laptop, and a PowerEdge 2650 - all running Gentoo. Now if only I can get a car and plane to run it. Take a look at my Gallery! |
