Tuniq Symmetry ATX Case
PostPosted: Fri, 24 Mar 2006 00:16:05    Post Subject: Tuniq Symmetry ATX Case Reply with quote View Single Post
The software to control the display is not included with the case and needs to be downloaded from their website... Once the software is installed it is simple to control the bright blue display which doubles as a high temperature alarm. The only problem with this is if you like to set your motherboard up to power the USB connections when the computer is off, the bright blue light will remain on. - The Review
