Joined: 07 Apr 2003 Posts: 20352 Location: New Jersey
Posted: Wed, 14 Dec 2005 01:04:32 Post Subject: Raidmax Sagitta ATX Gaming Case
This case offered one of the easiest installations I have ever completed. The unique design of the tool free setup holds drives in place better than any I have seen. The hard drive bay is turned 90° to ease installation, and as seen previously, the motherboard tray comes out of the case to simplify that step. - The Review
Last edited by Doctor Feelgood on Tue, 02 May 2006 16:40:47; edited 1 time in total
Posted: Sun, 30 Apr 2006 22:13:54 Post Subject:
Hi Big B... Nice screen name!
Yes, this case will take a mATX case, and the I/O shield can be removed. It looks permanent since it is the same dull colored steel, but it does come out. You can see it has been switched for one specific to the motherboard being used for test in this image:
Will the PSU that comes with this case work good for along time or should i buy a new psu.I dont overclock and i have a soso gaming pc . I have a 6800 gt ,1 dvd-rw/cd-rw drive, one dvd drive.one floppy and one 250 GB harddrive. I have a 3.2GHz prescott cpu.So should i buy a better psu ? I plan on buying this case.
Posted: Tue, 02 May 2006 21:49:02 Post Subject:
You can generally daisy chain fan connectors (hook them all together and use one PSU plug), so that should be an issue. Vid card is generally off the motherboard, if not off the vid card itself. Do you have something different?
