Posted: Tue, 30 Aug 2022 10:54:45 Post Subject: Cooler Master XG850 Plus Platinum 850W Power Supply |
The Cooler Master XG850 Plus Platinum 850W is a very quiet power supply regardless of the amount of power being drawn. Under idle level loads, the XG850 Plus Platinum is nearly inaudible, because the fan is running at only around 700 RPM. Under moderate to high loads, the XG850 Plus Platinum is still nearly inaudible, as the fan is capped at around 750 RPM. You cannot change the fan speed profile in software. aphnetworks.com |
