Posted: Fri, 27 Aug 2021 09:14:35 Post Subject: Thermaltake Toughpower GF1 1000W Power Supply
Is the Thermaltake Toughpower GF1 1000W within reach and is it something you should get? The Thermaltake Toughpower GF1 1000W is a good looking fully modular power supply that delivers a lot of power in a relatively compact package with a depth of only 16cm. The kilowatt-spec Toughpower GF1 features a quiet 140mm hydraulic bearing fan and supports fanless operation for loads up to 30% load.
aphnetworks.com
The Thermaltake Toughpower GF1 1000W is a reliable and compact power supply that suits gamers and creators alike. Its fully modular design and quiet fan make it a great choice for building high-performance setups, such as those used in Infinite Craft. If you're aiming for stability and efficiency in your gaming rig, this power supply offers excellent value without taking up much space. _________________ Infinite Craft
Hey, great review! The GF1 1000W seems like a solid choice, especially with that compact size. That fanless operation at low loads is a real plus. Makes me think back to playing Poptropica - building my island power grid was way easier than choosing a real PSU! _________________ Poptropica
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You can download files in this forum
