Silicon Power 2x16GB DDR4-3200 XPOWER Turbine RGB Memory Kit
madshrimps.be
Post new topic   Reply to topic    Bigbruin.com Forum Index -> News
PostPosted: Wed, 19 Feb 2020 09:59:25    Post Subject: Silicon Power 2x16GB DDR4-3200 XPOWER Turbine RGB Memory Kit Reply with quote View Single Post
The XPOWER Turbine RGB 32GB kit from Silicon Power does offer wide compatibility for configuration in terms of LED lighting, while the Samsung ICs are carefully selected from the factory, in order to stay stable at the programmed XMP timings. In our case, the kit has performed interestingly well at 3000MHz instead of the rated 3200Mhz, which leaves us suspecting that the pre-programmed timings were more relaxed than the kit was capable of. When testing with the rated CAS timings and leaving the others on Auto, we managed to squeeze more performance out of the kit, but going further was not possible since the system was unable to boot. madshrimps.be
Post new topic   Reply to topic    Bigbruin.com Forum Index -> News All times are GMT - 4 Hours
