Ice Bank Mice Elf
Posted: Mon, 20 Nov 2017 14:15:43 Post Subject: Patriot Memory Viper 4 Series DDR4 32GB 3000MHz Memory Kit |
The Viper 4 Series DDR4 32GB 3000MHz kit from Patriot Memory is not as flashy as other RGB offerings we have tested from other manufacturers, but comes with a good quality aluminum heat spreader for fast heat dissipation, while using the airflow inside the computer case. 32GB of RAM should be enough for most todays’ games and productivity applications, while most systems should be able to run this kit at the stock speeds without issues, thanks to the pre-programmed XMP 2.0 profile. madshrimps.be _________________ boom! |
