MBED compiler for NRF51822 Bluetooth
AdrianWong
PostPosted: Sun, 24 Sep 2017 01:21:38    Post Subject: MBED compiler for NRF51822 Bluetooth Reply with quote View Single Post
We have been utilizing nrF51822-mKIT for code improvement and as of late got nrF51822 Bluetooth smart beacon kit. There is want to utilize nrF51822 Bluetooth smart beacon kit for testing as a result of the smaller size.
When we took a gander at the "blinky" application on MBED, one distinction between the two stages wound up plainly self-evident. On nrF51822-mKIT, LED1 and LED2 are associated with GPIO P0.18 and P0.19, individually. Then again, nrF51822 Bluetooth smart beacon kit has a 3-shading LED which is associated with GPIOs P0.12, P0.16, and P0.17.
So, in that spot we see incompatibility and that influenced us to think about whether one ought to try and attempt to utilize MBED to accumulate code for nrF51822 Bluetooth Smart Beacon Kit?
Any advice?
opinionundress
PostPosted: Tue, 18 Feb 2025 23:11:17    Post Subject: Reply with quote View Single Post
Yes, you can use MBED, but you'll need to update GPIO mappings for LEDs and check SoftDevice compatibility. The Beacon Kit isn't officially supported, so you may need a custom MBED target. Nordic’s SDK might be a better option. Need help adapting your code?
