Anti-virus need advice
AdrianWong
PostPosted: Mon, 18 Sep 2017 07:32:14    Post Subject: Anti-virus need advice Reply with quote View Single Post
Hi,
Which anti-virus would be the best antivirus for windows 10 pro. Now I'm using Avast.
Thanks.
PostPosted: Fri, 22 Sep 2017 13:00:50    Post Subject: Reply with quote View Single Post
I just let Windows Defender run... Its already installed and handles its updates just fine without anything else needed.
AdrianWong
PostPosted: Fri, 22 Sep 2017 13:19:38    Post Subject: Reply with quote View Single Post
Thanks for your reply!
Windows Defender is by default if I up to date it, is there no need to install other Antivirus?
byronpaul
PostPosted: Tue, 31 Oct 2017 04:36:43    Post Subject: Reply with quote View Single Post
Windows defender is good enough for me.
Rall
PostPosted: Mon, 06 Nov 2017 08:02:09    Post Subject: Reply with quote View Single Post
Actually, which one is the best?
quadbikedubai
PostPosted: Fri, 03 Jan 2025 14:48:26    Post Subject: Reply with quote View Single Post
For Windows 10 Pro, Windows Defender is a solid option. However, if you want extra features, consider Bitdefender, Norton, or ESET for strong security. Avast is also a good choice, offering reliable protection, but if you're looking for advanced features, you might want to explore alternatives. The best antivirus depends on your specific needs.
escaperoad
PostPosted: Sun, 05 Jan 2025 23:01:04    Post Subject: Reply with quote View Single Post
I'd also recommend checking out Kaspersky. It's been consistently strong in independent tests, and its interface is really user-friendly.
natalie321
PostPosted: Tue, 01 Apr 2025 05:12:57    Post Subject: Reply with quote View Single Post
If you prefer a free option, Microsoft Defender is reliable and lightweight for everyday use.
hannabaker
PostPosted: Mon, 14 Apr 2025 08:21:37    Post Subject: Reply with quote View Single Post
Well, there are so many antivirus programs available, but personally, I use Quick Heal.
somit
PostPosted: Thu, 12 Jun 2025 05:57:15    Post Subject: Reply with quote View Single Post
You don't need any antivirus. if you are using Windows 11 then you have the best security and web protection.
https://www.mailsdaddy.com/mbox-to-pst-converter/
