![](images/avatars/gallery/Pop/Dr_Feelgood.jpg)
Posted: Thu, 30 Dec 2004 11:33:32 Post Subject: mCubed T-Balancer Fan Controller |
![](http://www.bigbruin.com/reviews/tbalancer/logo.gif) | Rarely does a product emerge that is truly new and different. The T-Balancer from mCubed is exactly that. There are many ways to control the speed of fans on a computer. The most common involves some sort of a fanbus or rheostat with knobs on the front... The T-Balancer is nothing even remotely close to a fanbus. - The Review |
Last edited by Doctor Feelgood on Mon, 01 May 2006 22:49:32; edited 1 time in total |
![](templates/subSilver/images/spacer.gif) |
ragzilla Rated PG
Posted: Fri, 31 Dec 2004 16:04:44 Post Subject: |
the zener is not a temp sensor, it's most common use in a circuit like this is as a voltage regular, a zener is rated for a certain amount of reverse voltage breakdown at which point it avalanches and starts to conduct in the reverse direction as described at http://hyperphysics.phy-astr.gsu.edu/hbase/electronic/zenereg.html#c1
the temp sensor is that LM75A IC next to the zener, manufactured by philips it's a digital temperature reader that communicates over an I2C bus (which is where the 8 device limit comes from).
http://www.semiconductors.philips.com/pip/LM75AD.html
-edit-
added reply notify
-/edit- |
MagnusT Rated PG
Posted: Fri, 31 Dec 2004 20:11:31 Post Subject: |
Integration with LCD displays works with v2.1.1 of TBAN's software
I had some fun testing different variants on my own PC:
![](http://tystpc.nu/pics/software2/Tban2_jaLCDs_emulator.gif) |
Spire Hall Pass B!tch!!!
![](images/avatars/Uploaded/89615759446ee16111fbed.jpg)
Joined: 01 Aug 2003 Posts: 2165 Location: Up to my Nipples in Alaska
avantime Rated PG
Posted: Sat, 01 Jan 2005 23:53:37 Post Subject: |
In the review they said false information on other controllers
- the T-Balancer is able to take a fan from full speed to completely off, something no voltage-varying controller is able to do
I have a sunbeam 4 port rheobus fan controller (a voltage-varying controller) and can go from 0 to 12 volts...
![Confused](images/smiles/confused.gif) |
Posted: Sun, 02 Jan 2005 00:51:33 Post Subject: |
The large silver one you got a while ago was from Sunbeam (definitely could not stop a fan)... the small one was from Noise Isolator.
This Evercool one stopped fans though... http://www.bigbruin.com/html/evercool-scpa.htm ![Laughing](images/smiles/laughing.gif) |
