| Controlling your HVAC system is incredibly easy through either the ecobee3 Wi-Fi smart thermostat, apps, or web portal. The touch screen responds quickly to your input and menus are easy to navigate. The thermostat always displays the current temperature and outdoor temperature and weather icon. As you approach the thermostat the display will change, centered will be your current temperature with a humidity reading just above that. |
