Joined: 07 Apr 2003 Posts: 20348 Location: New Jersey
Posted: Wed, 05 Dec 2012 10:06:34 Post Subject:
The APM-J011-WS sent over by Geeks.com works very well. Initially I wasn't sure what I should expect from this lower priced, generically packaged unit. Because the APM-J011-WS is so much like a Foscam camera, I wound up being very pleased. It was extremely easy to setup, the feature-packed interface is nearly identical, and every day use is quite simple.
How blurred are the images when your watching people walk by in real time? If you were recording video would you be able to identify a person's face? _________________ - Jim
Posted: Fri, 07 Dec 2012 11:24:57 Post Subject:
They are clear... They run at 30 fps, so you get a decent look at whatever is going on. If someone is running straight across the frame the image will be blurred, but if they are walking across, or coming towards the camera you will get a good look.
These don't record video out of the box - but you can use third party software to do so.
