Posted: Tue, 08 Nov 2011 10:41:19 Post Subject: Win a Kingston HyperX 128GB External Drive |
NFL Week Ten
This week's prize is sponsored by Kingston... the world’s independent memory leader!
Up for grabs is a Kingston HyperX Max 3.0 128 GB Flash Drive (part number SHX100U3/128G) as seen on the Kingston website and at Amazon.com.
Kingston's HyperX MAX 3.0 has a read speed of up to 195MB/sec., and a write speed of up to 160MB/sec., when paired with a USB 3.0 compatible device. It is also fully compatible with USB 2.0 devices, as the speed defaults back to USB 2.0 capability. During internal testing, a 10GB movie file was transferred in only 1 minute, 12 seconds to the HyperX MAX 3.0 from a USB 3.0 system*. The transfer time increased to 5 minutes, 52 seconds using a USB 2.0 port with the same test bed.
Scoring:
» 5 points per game for picking the winner
» 5 extra points (10 total) per game for picking the exact score
The winner of the contest is determined by which ever entrant has the most points at the end of all games this week. If the contest should end in a tie based on points alone, the tie breaker will be determined by which entrant has the lowest point differential. The point differential takes the absolute value of the difference between the actual score and your predicted score for each game, and adds them all together.
Rules:
1. You have until kick off of each game to make your picks, once a game starts you will not be able to change your pick.
2. To play you must be a registered member of the Bigbruin.com forum.
3. One winner will be chosen based on the final score of the contest.
4. At the end of the contest, the winner must provide their shipping address, and the prize will ship out right away.
5. This contest is open to participants in the USA and Canada only, and shipping is included.
6. Rules subject to change.
Tips:
1. Your picks aren't set in stone until game time. You can edit your predictions for any particular game as often as you want right up to kick off.
2. Once games have started, you can see your predictions and how they compare to actual results by clicking your name as listed on the main page of the game.
3. The main page of the game shows cumulative season stats, which have no bearing on winning the prize for any given week. Just ignore them! To see weekly scores - click here - and scroll to the current week.
4. Winners have two weeks to claim their prize - otherwise it will be forfeit.
Last edited by Doctor Feelgood on Tue, 08 Nov 2011 15:49:31; edited 1 time in total |
skarydrunkguy Rated XXX
Joined: 14 Sep 2009 Posts: 237 Location: under your bed
James86 Rated R
Posted: Tue, 08 Nov 2011 22:53:41 Post Subject: |
| James86 wrote: | | Is there an SSD inside that case??? |
It seems like an SSD - but they simply describe it as having a "Flash memory-based architecture". I was even corrected by a Kingston rep when I called it an SSD... So I would say "NO" to your question.  |
BeerCheeze *hick*
Posted: Tue, 08 Nov 2011 23:33:23 Post Subject: |
It's 4 32GB SD cards in RAID-0!
I don't actually know that BTW, but when I win I'll tell you.  |
PopcornMachine Rated PG-13
Posted: Wed, 09 Nov 2011 15:18:18 Post Subject: |
Looks like a very nice prize regardless of what's in there.  |
Posted: Wed, 09 Nov 2011 21:34:43 Post Subject: |
Posted: Wed, 09 Nov 2011 21:57:27 Post Subject: |
Nice find! And pretty cool innards!  |
BeerCheeze *hick*
Posted: Thu, 10 Nov 2011 12:39:54 Post Subject: |
Cool. HEHEHE... last time I took apart a flash memory system for a reivew, I ticked off the manufacture.  |
James86 Rated R
