ASUS Cine5 5-Channel PC Speaker
http://www.bigbruin.com/content/asuscine5_1
Post new topic   Reply to topic    Bigbruin.com Forum Index -> Audio
PostPosted: Fri, 13 Aug 2010 06:27:58    Post Subject: Reply with quote View Single Post
The Cine5 has quite a few things going for it. First and foremost, it's footprint is significantly smaller than a traditional 5.1 speaker system so you don't need to plan out where you are going to fit all the pieces. If you are using it at your desk it should fit nicely right under your widescreen LCD monitor, and the sleek style will have it looking right at home at the same time.
Post new topic   Reply to topic    Bigbruin.com Forum Index -> Audio All times are GMT - 4 Hours
