Thermalright SLK-800U Heatsink
Post new topic   Reply to topic    Bigbruin.com Forum Index -> Cooling
PostPosted: Fri, 18 Jul 2003 11:54:23    Post Subject: Thermalright SLK-800U Heatsink Reply with quote View Single Post
Check out the Bigbruin.Com review: **HERE**
And share your comments / questions in this thread... Thanks!
Last edited by Doctor Feelgood on Sun, 30 Apr 2006 14:04:47; edited 2 times in total
garnold
PostPosted: Fri, 19 Sep 2003 13:56:50    Post Subject: Reply with quote View Single Post
Can I use something like this on my intel chip? Just looking to get some new tools for the machine and need a better cpu cooler.
PostPosted: Fri, 19 Sep 2003 13:58:45    Post Subject: Reply with quote View Single Post
TFB wrote:
Can I just something like this on my intel chip? Just looking to get some new tools for the machine and need a better cpu cooler.
I'd offer to get a sample for you to review (I actually have P4 stuff I can't review)... But, umm... Yikes
To answer the question, yes. That same model fits a P4 and includes the necessary brackets!
garnold
PostPosted: Fri, 19 Sep 2003 15:21:12    Post Subject: Reply with quote View Single Post
I'm sorry I'm such a review looser Sad I thought what I had but together would cover it but the reviews on this site are very tech-ie which makes them very good. I told FB that I'm going to order that product and give it back to you so we are square. Again sorry.
On another note I am looking for some fans to cool the machine done so I can play with OC'ing. If this one is good I'll head over to New Egg and add it to my list.
PostPosted: Fri, 19 Sep 2003 15:24:32    Post Subject: Reply with quote View Single Post
It is a good cooler, but it costs a little more than others, and doesn't actually include a fan. The stock one isn't cutting it for you?
Don't worry about replacing the psu... I have a second one. I had planned on giving one away in a contest... I guess you won... Laughing
Bang Head
garnold
PostPosted: Fri, 19 Sep 2003 21:22:12    Post Subject: Reply with quote View Single Post
Well I wanted to start to OC some and just figured I would play it safe and get a better cooler before I burnt out the chip. Can you/anyone recommend a good cooler for an intel chip then?
PostPosted: Fri, 19 Sep 2003 21:38:58    Post Subject: Reply with quote View Single Post
That would definitely be a good one... Or the even bigger and badder SLK-900. It will support a 92mm fan (compared to mine with a 80mm), which should give you more airflow and even less noise
