Arctic Cooling 4Pro L Pentium 4 Heatsink
Post new topic   Reply to topic    Bigbruin.com Forum Index -> Cooling
PostPosted: Wed, 10 Mar 2004 17:08:15    Post Subject: Arctic Cooling 4Pro L Pentium 4 Heatsink Reply with quote View Single Post
Check out the Bigbruin.Com review: **HERE**
And share your comments / questions in this thread... Thanks!
Last edited by Doctor Feelgood on Mon, 01 May 2006 22:51:22; edited 2 times in total
george042369
PostPosted: Fri, 19 Mar 2004 14:47:04    Post Subject: Reply with quote View Single Post
Most heatsinks that are a hybrid copper/aluminum don't really gain anything from this. Part of my job entails testing different heatsinks and designs to see how the work. However the additional thermal junction created by inlaying copper into aluminum negates any gains from using the copper in most instances. Now in a design like Swiftech uses of a copper base with aluminum pins this works very well and gives the best of both worlds. So just because it has copper in the CPU die area; doesn't mean it will perform better. Anyway these are just some thoughts I thought you may benefit from. Keep up the good work.
trekrider
Feeling: Prehistoric
PostPosted: Fri, 19 Mar 2004 14:58:27    Post Subject: Reply with quote View Single Post
george042369...Welcome to BigBruin.com
What, exactly, do you do.......and whom do you do it for??
Two wrongs don't make a right!
But, three lefts do!!
PostPosted: Fri, 19 Mar 2004 15:17:45    Post Subject: Reply with quote View Single Post
Thanks George, and welcome.
Although I do know what you mean... I won't fully agree with you. I have received heatsinks from Speeze that helped confirm that the copper core must do something! I reviewed two coolers, identical except for the fans and that one was all aluminum and the other was the same aluminum body with a copper core. If you used the same fan on both coolers, the AlCu one beat the all Al one by 3-4C with all other factors held constant. I mentioned my plans for testing with the same fan in the review, but didn't document them at that time.
Some heatsinks have the copper bolt to the aluminum or otherwise have a poor interface, but these (and others) have the copper press fit in and the heat transfer has to be pretty good. Otherwise, why would so many manufacturers offer heatsinks like this?
I'd be interested in hearing more about what you do to... This place could use some real science!
