NZXT Precise 1200W Power Supply
Post new topic   Reply to topic    Bigbruin.com Forum Index -> Power
PostPosted: Thu, 12 Jul 2007 07:41:34    Post Subject: NZXT Precise 1200W Power Supply Reply with quote View Single Post
To put it simply, the Precise 1200W Power Supply is superb. The voltage regulation is way above par, the overall build quality is very good, and it has a simple design without any gawdy extras. But unless your middle name is "Overkill", then it will honestly be a lot more power than you could possibly need. - The Review
Post new topic   Reply to topic    Bigbruin.com Forum Index -> Power All times are GMT - 4 Hours
