brawls Rated PG
tlsrulz Rated PG
Posted: Mon, 23 Jul 2007 16:00:17 Post Subject: will thermalright ultra 120 extreme fit |
Hi,
Can you tell me what heatsink you used for the review. I want to know if the ultra 120 will fit. I will be running a Q6600
Thanks
TLS RULZ |
tlsrulz Rated PG
Posted: Wed, 25 Jul 2007 18:25:26 Post Subject: |
I have the system torn apart right now, without a motherboard in there, so I can't provide you exact measurements.
I can say though, if you look at the 120mm fan in the picture on this page:
http://www.bigbruin.com/2007/cmmedia280_4
The 120mm fan goes right to the edge of the top of the case. So you would have 120mm from the top of the keyboard port key (which is approximately 45mm).
It's doubtful that the Thermalright 120 will fit. If it did, it would be VERY tight. |
