Vizo Luxon 3.5 Inch IDE/SATA Hard Drive Enclosure
Post new topic   Reply to topic    Bigbruin.com Forum Index -> Storage
PostPosted: Wed, 16 Aug 2006 06:59:23    Post Subject: Vizo Luxon 3.5 Inch IDE/SATA Hard Drive Enclosure Reply with quote View Single Post
Installation is simple, all that is necessary is to slide the tray out of the external chassis and connect your hard drive of choice. On the bottom of the tray you use four screws to secure your drive. The final part of installation is to slide the tray into the enclosure and secure it with four hex screws (two on each side). - The Review
euroiplayer
PostPosted: Thu, 23 Nov 2006 07:40:30    Post Subject: Vizo Luxon 3.5 Inch IDE/SATA Hard Drive Enclosure Reply with quote View Single Post
Hello Big Bruin,
First off I would like to say great forum.
This is what I was just looking for. A Hard Drive Case Enclosure that supports both IDE and Serial ATA data cables!
After doing some searching for other brands, this was the only one that supports both IDE and Serial ATA. And I don't know if I should get this or what, the reason I am asking this is that since I've never heard this brand name -- I am thinking it might not be that good, but I might be wrong (I guess I am being dumb and looking for a well known brand name, its amazing how brains get tricked when it comes to that Bang Head ).
Tell me what you think, should I get the Vizo Luxon 3.5 Inch IDE/SATA Hard Drive Enclosure...?
Thanks Smile
PostPosted: Thu, 23 Nov 2006 11:04:33    Post Subject: Reply with quote View Single Post
The drive enclosure is still in use, and used every day under pretty heavy usage. I've had no issues with it at all.
euroiplayer
PostPosted: Thu, 23 Nov 2006 18:13:22    Post Subject: Vizo Luxon 3.5 Inch IDE/SATA Hard Drive Enclosure Reply with quote View Single Post
Thanks for the info Hellfire.
Tridoros
PostPosted: Sun, 31 Dec 2006 19:13:33    Post Subject: Vizo Luxon 3.5" IDE/SATA Hard Drive Enclosu Reply with quote View Single Post
Is the tray for the hard drive, metal or plastic on the Luxon?
Thanks
PostPosted: Mon, 01 Jan 2007 00:54:16    Post Subject: Reply with quote View Single Post
The entire tray is plastic, however where the hard drive goes there is a piece of metal/aluminum on the bottom.
Post new topic   Reply to topic    Bigbruin.com Forum Index -> Storage All times are GMT - 4 Hours
