Thermaltake Armor/Kandalf Side Panel Upgrade with 25cm Fan
PostPosted: Tue, 08 Aug 2006 06:36:13    Post Subject: Thermaltake Armor/Kandalf Side Panel Upgrade with 25cm Fan Reply with quote View Single Post
This add on for your Thermaltake Armor or Kandalf case may be just the thing you need to cut a few degrees off your hot system... All while generating no extra noise. The 25cm fan silently cut 4 degrees Celsius from our well cooled test system's processor, and I am confident that the results in other configurations may be even better. - The Review
Modulok
PostPosted: Wed, 09 Aug 2006 12:04:44    Post Subject: Reply with quote View Single Post
You know that 25cm fan looks the same as the Enermax Chakra one I reviewed...except a TT sticker, haha.
tunedbysti
PostPosted: Fri, 15 Sep 2006 14:22:07    Post Subject: Reply with quote View Single Post
Do you think this sidepanel would interfere with a Zalman CNPS9500 LED CPU Cooler in the armor case? Just curious because i do not want to buy the side panel only to find out that it does not fit.
Thanks for the help
Daniel
PostPosted: Fri, 15 Sep 2006 15:12:14    Post Subject: Reply with quote View Single Post
Hi... Could you tell me how tall that cooler is? Or link me.
I used the Tuniq Tower 120 which is just over 150cm tall and it barely interfered.
tunedbysti
PostPosted: Fri, 15 Sep 2006 15:33:34    Post Subject: Reply with quote View Single Post
http://techreport.com/reviews/2005q4/zalman-cnps9500/index.x?pg=1
There is a link to a review on the cooler itself.
Thanks for the quick response.
Daniel
PostPosted: Fri, 15 Sep 2006 17:51:12    Post Subject: Reply with quote View Single Post
That should be fine... That review says it is 125cm tall... thats about an inch shorter than the Tuniq Tower and it should clear easily.
tunedbysti
PostPosted: Fri, 15 Sep 2006 19:50:41    Post Subject: Reply with quote View Single Post
nice. thanks for the help bro.
Daniel
bruceleeon
PostPosted: Sun, 17 Sep 2006 21:40:55    Post Subject: Reply with quote View Single Post
Why not just water cool?
PostPosted: Mon, 18 Sep 2006 10:41:37    Post Subject: Reply with quote View Single Post
Laughing - just a bit of a price difference... these side panels are $30ish.
rockiNmyComP
PostPosted: Sun, 12 Jul 2009 14:33:13    Post Subject: Reply with quote View Single Post
where can i buy this????
