On a windows 2000 domain how do you disable internet access
JimBowy
Moderator
PostPosted: Mon, 16 Jan 2006 22:03:03    Post Subject: On a windows 2000 domain how do you disable internet access Reply with quote View Single Post
I want to prevent a user from getting online, but still allow them access to the local network (if easily possible) does anybody know how to do so?
The local router serves as DHCP.
- Jim
PostPosted: Mon, 16 Jan 2006 22:24:48    Post Subject: Reply with quote View Single Post
Disable DHCP, give them a hard coded IP address and no default (or wrong default) gateway address.
Assuming the don't have Admin rights to change it of course. Otherwise just block them at the router (either by MAC address or IP address)
Kilamon
PostPosted: Tue, 17 Jan 2006 13:45:30    Post Subject: Reply with quote View Single Post
Install a firewall with session authentication. Smile
