efesar Rated PG
Posted: Fri, 22 Jul 2005 15:31:30 Post Subject: |
Welcome efesar!
The utility I used for the Seagate and Hitachi reviews published this week was actually provided with the Promise controller. They call it PAM, and you just click to enable/disable NCQ, and then reboot.
Hopefully someone with more nForce4 insight can chime in on that end of it for you... |
efesar Rated PG
Posted: Fri, 22 Jul 2005 15:45:20 Post Subject: |
Big Bruin wrote: | Hopefully someone with more nForce4 insight can chime in on that end of it for you... |
Hey I did find something. Maybe this will help anybody who is looking.
Device Manager, go to the properties for the SATA controller. If the checkbox for NCQ is enabled, the drive supports it and it is enabled. According to Seagate, NCQ is enabled in the drive from the factory.
For the record, mine is on and automatically checked. I'm running the Seagates in a new file server (about 30 clients) and it blows away the old file server which had SCSI 160, about 8 10k & 15k drives (various generations) -- although for fairness, it was an old system with dual 350MHz P2's, so the bus, memory and CPU limitations probably bottlenecked the drives.
Big Bruin, thanks for the article and the comparison. Very helpful. Are you going to test those drives out in a RAID 0 comparison soon? I'd like to read that for both the Hitachi's and the Seagates. _________________ -k |
Posted: Fri, 22 Jul 2005 15:49:50 Post Subject: |
I asked for a pair of the Hitachi's but I imagine the price was prohibitive for a sample request like that ($800ish for two drives)!
I may be able to borrow one, we'll see, but nothing official will be coming from Hitachi.
I hope to get the Seagate's tested on a nForce4 RAID controller, since I have the pair, and the PCI bus was no doubt the bottle neck for their performance.
Next up... Maxtor SATA drives...  |
jay2115 Rated PG
martins Rated PG
Posted: Mon, 25 Jul 2005 08:14:02 Post Subject: Re: HDD Controller |
martins wrote: | Hi,
would it be possible to get a better picture of the HDD controller from the drive (The 144-LQFP in the middle of the board) ? I wonder about the brand/model of this chip.
Regards,
Martin |
Will do... But not until I get home in about 10 hours! |
Ysean Rated PG
