SLAX Linux
PostPosted: Thu, 09 Jun 2005 13:50:16    Post Subject: SLAX Linux Reply with quote View Single Post
Quote:
SLAX is a small bootable CD containing the Linux operating system. It runs Linux directly from the CD (or USB) without installing. The Live CD described here is based on the Slackware Linux distribution and uses Unification File System (also known as unionfs), allowing read-only filesystem to behave as a writable one, saving all changes to memory.
SLAX
I am getting it now to try on a 512MB thumbdrive.... Grin
IceNine
*The Freshest*
PostPosted: Thu, 09 Jun 2005 14:04:06    Post Subject: Reply with quote View Single Post
I've used this for a while. I have it on a mini cd Smile
A letter to a soldier
travis
PostPosted: Thu, 16 Jun 2005 22:18:43    Post Subject: Reply with quote View Single Post
i want to put it on a thumb drive as well how will i go about doing that? I have Nero 6 if that helps.
PostPosted: Thu, 16 Jun 2005 22:39:16    Post Subject: Reply with quote View Single Post
I never got that working either... Worked fine on CDs... tried a few ways to get it going on a thumb drive and it wouldn't boot on any system, even if they did support booting from USB.
PostPosted: Thu, 16 Jun 2005 23:12:59    Post Subject: Reply with quote View Single Post
Make sure your Bios has USB 1.1 enabled....I found that out when none of my USB keyboards would work when installing XP, but they do work in Windows, and to open the bios. Was wierd...checked the Bios and noticed it had USB 2.0 enabled, but not USB Legacy 1.1, enabled that and it went without a hitch.
Not sure if that'll fix the booting from usb or not though BB.
