Computer Cases
Post new topic   Reply to topic    Bigbruin.com Forum Index -> Hardware Share:
Asthetic
PostPosted: Fri, 26 Feb 2010 20:24:25    Post Subject: Computer Cases Reply with quote View Single Post
I am getting a list of parts that I would like in order to make my own computer. I have never made my own and thought It would be a great expierence (Im interested in IT as a profession). So far I have everything I would like to buy... execpt the case. I want to make sure I can get a case big enough for the parts I want. Because of the place I am putting the computer i believe it needs to be a Mid Tower.
(Posting parts that take up a large ammount of space)
Motherboard:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131366R&cm_re=asus_m4a78t-e-_-13-131-366R-_-Product
Hard-Drive:
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148395&Tpk=st3500418as
Video-Card:
http://www.bestbuy.com/site/PNY+-+NVIDIA+GeForce+XLR8+GTX+260+896MB+DDR3+PCI+Express+Graphics+Card/9262424.p?id=1218071137116&skuId=9262424
CD/DVD drive:
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106300
PSU:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817171034
I hope I will find this process enjoyable... Any tips from the people who have expierence with this type of stuff?
~Jordon~
PostPosted: Sat, 27 Feb 2010 22:07:09    Post Subject: Reply with quote View Single Post
Hi - Some questions...
What processor do you plan to use?
Did you look on Newegg for a video card, too? Best Buy generally isn't the "best buy"... the GTX260 should be less than that.
From what I see so far - that PSU is overkill and a waste of money. Look for something 550-750W... Something similar to what you listed at 700W - http://www.newegg.com/Product/Product.aspx?Item=N82E16817171032
Asthetic
PostPosted: Thu, 04 Mar 2010 16:21:36    Post Subject: Reply with quote View Single Post
This is pritty much a dream build... If I can save up the money this summer.
CPU was
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103727
I used a PSU calculator for the powersupply.
http://extreme.outervision.com/psucalculatorlite.jsp
~Jordon~
slugbug
PostPosted: Fri, 05 Mar 2010 12:04:10    Post Subject: Reply with quote View Single Post
I used a Thermaltake Element G case for my recent build. It has a top fan controller knob which lets you adjust the fan speeds as well as choose one of four LED colors or none.
If you use a large cpu cooler you may need to remove the top fan though..I did.
Moderator
PostPosted: Fri, 05 Mar 2010 12:43:22    Post Subject: Reply with quote View Single Post
I still really like the CoolerMaster HAF, a new version was just announced at Cebit, the HAF X. Looks really nice Smile If your space allows for it anyways LOL
(TSC)Bender
PostPosted: Sat, 06 Mar 2010 12:00:10    Post Subject: Reply with quote View Single Post
You can definitely go with a smaller PSU. I have a similar setup, except with an ATI Radeon HD4850X2 (still running great), and it runs great on a 650 watt PSU.
As for cases, the previously mentioned ones are solid choices. I've been pleased with the CM Sniper so far, which is a midtower variation of the HAF.
Optix
PostPosted: Thu, 25 Mar 2010 20:54:57    Post Subject: Reply with quote View Single Post
On the cheap - Antec Three Hundred
Middle of the road - Cooler Master HAF 922
More money than brains - Silverstone Raven 02
Gigabyte H55M-USB3/Intel i3 530/CoolIT Vantage 240 A.L.C./G.Skill Eco DDR3 1600
Sapphire 6850 Toxic Edition/Western Digital 640GB Caviar Black/LG GH22LS50 DVD Writer
Ultra X4 850w PSU/Lian Li PC-P50WB
View user's profile Send private message MSN Messenger
Moderator
PostPosted: Fri, 26 Mar 2010 07:58:21    Post Subject: Reply with quote View Single Post
Nah....
More money than brains - Thermaltake Level 10
crowTrobot
PostPosted: Fri, 26 Mar 2010 09:52:29    Post Subject: Reply with quote View Single Post
Raven is a pretty good case.
More money than brains = That insane giant Zalman case that costs $1000. I think if you go to newegg and arrange the cases by cost it's the highest one there.
PostPosted: Fri, 26 Mar 2010 10:04:45    Post Subject: Reply with quote View Single Post
Three Hundred is a great case.
Post new topic   Reply to topic    Bigbruin.com Forum Index -> Hardware All times are GMT - 5 Hours
