jedihobbit Rated XXX
Joined: 22 Mar 2007 Posts: 238 Location: Central Virginia, USA
Posted: Sat, 05 Dec 2009 12:48:48 Post Subject: Will nvidia nForce2 SPP work with SATA II? |
Okay started this question over here http://www.bigbruin.com/forum/viewtopic.php?t=23737 but now want to get away from a specific brand..........
Now the question is does anyone know if there would be issues between the SATA150 controller in the nForce2 SPP chip if one installs a SATA 300 1 to 2TB hard drive? _________________ As of 02/01/11
DreamCatcher AM3 >> (Down Again) >> SG01 Evo, MSI 785GM-E65, PII X4 955(AQ H2O Cooled), XFX GTX285(EK H2O Cooled), Seagate 7200.10 ST380815AS 80GB, 2 x G.S. F3-12800CL7D-2GBPI, MODU82+ EMD525AWT, XP Home SP2
KestrelFlight >> (Under Construction) >> Zalman Z7+, MSI NF980-G65, PII X4 1055T, 2 x Galaxy 580GTXs, Zalman 32GB SSD, WD V'Raptor 300GB, 2 x WD 1 TB Blacks, G.S. F3-16000CL9D-4GBTD, Zalman ZM1000-HP Plus , Win7
Oz1a v2.0 >> XFX MDA72P7509 750a, PI X2 8870BE, 2 x XFX GTS250, WD 250GB, F2-8500CL5D-2GBPK, Tt TR2 600W, XP Pro SP3 |
BeerCheeze *hick*
Posted: Sat, 05 Dec 2009 17:14:46 Post Subject: |
Should be fine, just make sure to hard set the HDD to SATA 1 speed (there is normally a jumper). _________________
Posted: Sat, 02 Jan 2010 22:26:04 Post Subject: |
Installed a WD2000CSRTL 2TB drive in the system (SKT A!) with basically 1 x 1TB and 2 x 500GB partitions. This HDD has the "mechanical" jumper to regress to 150.
Owner took it home today quit happy.......yesterday was a big b#@*h as his 80GB primary was swapped out for a 160 ( set 2 x 80) and wasted 1-1/2+ hours before it sunk in that I had a bad XP OS disk!  _________________ As of 02/01/11
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You can download files in this forum
