Joined: 07 Apr 2003 Posts: 18319 Location: New Jersey
trustdoc7 Rated PG
Posted: Mon, 29 Jan 2007 00:49:45 Post Subject: |
The company website says that you can play music without a T.V. by using the LCD on the Unit??? Can you see Folders/Files?
How long does the 4xAA battery pack last??
Thanks,
Alan |
Modulok Rated XXX
Posted: Tue, 30 Jan 2007 10:43:28 Post Subject: |
| trustdoc7 wrote: | The company website says that you can play music without a T.V. by using the LCD on the Unit??? Can you see Folders/Files?
Thanks,
Alan |
hmm, I didn't notice the jukebox w/o TV on the website...I will play with that and I will test the 4xAA battery pack. Any preference to audio or video playback on the battery pack? |
levyshahar Rated PG
Posted: Tue, 30 Jan 2007 11:55:44 Post Subject: |
Can anyone check if it supports WAV files?
I know the article says it does, but some of the stores don't mention it and I've had problems with this file type before (the iamm ntd-25 was supposed to support it but it didn't..)
Thanks!
Shahar |
Modulok Rated XXX
Posted: Tue, 30 Jan 2007 22:14:45 Post Subject: |
OK guys, here are your answers...
The battery pack is meant for the OTG backup feature. Meaning you can use 4xAA batteries to backup your digital camera photos, USB flash drives, etc. I don't think it is meant for audio or video playback.
When I put some freshly charged batteries in the pack and pluged it into the Rapsody nothing happened. Tried hitting the power button on the unit and still nothing. My guess is that the battery pack will not power my WD 120GB 5400RPM hard drive and needs extra power. I don't have a 4200RPM drive to try.
I looked through the manual about any meantion to the audio playback via LCD screen. I plugged in the Rapsody into my TV without the video cable. The only way where you can play audio files without the video plugged in is using the bookmark button on the remote. It remembers the last song and will resume it when you press the bookmark button.
As for the WAV playback, I had some old wav sounds from various TV shows/movies I used to use as Windows sounds. Some said unsupported, and the rest were not at the right speed...it was probably 2x too fast. It probably needs to be encoded a certain way like the divX and Xvid formats.
Hope this helps you both. |
levyshahar Rated PG
Posted: Wed, 31 Jan 2007 09:04:38 Post Subject: |
thank you for very quick response..
the problem is, if I encode the WAV files (to mp3, ogg, wma) they will lose data, since mp3 and the rest are all "lossy" formats.
some WAV files are not raw data but have some data that needs to be decoded..
the best way to check it is to use winamp option (in the media library) to rip a track from a cd to WAV file (with WAV header), and see if it plays it. I will appreciate it very much if you could do so...
and one more thing: how can I connect an optic or coaxial cables to it? these kind of cables require different output than the one I see in the picture..
thanks again
shahar |
Modulok Rated XXX
Posted: Wed, 31 Jan 2007 09:59:41 Post Subject: |
Give me the procedure in winamp and I will try to rip a track for you to see if it plays. Like I said in the review, I would like to see FLAC playback...not lossy and maybe 50% of the file size.
There are other cables available but sold separately. |
levyshahar Rated PG
Posted: Wed, 31 Jan 2007 11:04:32 Post Subject: |
the winamp procedure:
Alt+L for the media libraray, under "rip and burn", right-click the targeted CDROM device and choose "cd ripping preferences".
under encoding format, select ".WAV output". check "write .WAV header" (supposed to be checked already).
close the preferences window, choose a track and click "rip".
.FLAC is great, and it's free.. I really don't know why so little players offer it... but I'll be satisfied with wav for now...
thank man, you're really helpin me |
levyshahar Rated PG
Posted: Sat, 03 Feb 2007 17:30:47 Post Subject: |
| any luck with it yet? |
ntaurus2001 Rated PG
Posted: Sun, 04 Mar 2007 12:49:11 Post Subject: |
Has anyone had experience about the OTG function of Rapsody?
How long will the 4 AA batteries last when running the OTG?
How fast would it be, like, copy 2gb of images from USB card reader to Rapsody?
Thanks in advance. |
