My Opteron 148 OC Experience
Post new topic   Reply to topic    Bigbruin.com Forum Index -> Overclocking, Cooling, and Modding
Modulok
PostPosted: Tue, 04 Jul 2006 22:28:43    Post Subject: My Opteron 148 OC Experience Reply with quote View Single Post
I decided to start a thread that I can log exactly which steps I took to OC my new Opteron 148 on my DFI LanParty SLI-DR motherboard. I also want to share this here for any comments, suggestions, questions, etc. I will update this post as I go along.
My setup is the following:
  • DFI LanParty NF4 SLI-DR [official 04/06 bios]
  • AMD Opteron 148 2.2Ghz [CACJE.0604]
  • Thermalright XP90C [Copper CPU Heatsink]
  • GSkill Extreme Series DDR600 TCCD [2x512mb]
  • eVGA 7800gt co 256mb
  • Hitachi 80gb Sata II
  • OCZ Powerstream 520 watt
  • Pioneer 16x Dual Layer DVD Burner
For testing stability and benchmarking I used the following programs:
  • SmartGuardian
  • CPU-Z
  • Clockgen
  • A64 tweaker
  • Aquamark3
  • 3dmark03, 05, 06
  • Everest Home Edition
  • Sisoftware Sandra 2007
  • Memtest [Windows version]
  • Super PI
  • OCCT
  • Prime95
The first thing I did was test the system at stock speeds. It was kinda a challenge at first because the GSkill timings that had worked at ddr600 with my old A64 Venice weren't working with the Opty148. After some searching on DFI-Street and XtremeSystems I found some ram settings posted by the GSkill Technician for the exact motherboard/ram I am using. With these settings in place I did a fresh install of Windows [XP Pro with SP2] and installed the necessary drivers and programs.
Quote:
STABLE STOCK SETTINGS
200x11 @ 1.4vcore
DDR400 2-2-2-5 @ 2.6vdimm
FSB: 200
LDT: 5
Multi: 11
cpu vid: startup
cpu vid control: 1.400v
cpu vid special: x104%
ldt : 1.2v
chipset: 1.5v
dram: 2.60v
dram +.03v: disable
Dram Frequency Set: 200 (1:1)
CPC: Enable [1T]
Cas: 2
Trcd: 2
Tras: 5
Trp: 2
Trc: 7
Trfc: 13
Trrd: 2
Ter: 2
Twtr: 1
Trwt: 2
Tref: 3684
Dram Bank Interleave: Enable
Dqs Skew Control: Auto
Dqs Skew Value: 0
Dram Drive Strength: 7
Darm Date Drive Strength: 3
Max Async Latency: 6ns
Darm Response: Normal
Read Preamble Time: 4ns
Idlecycle Limit: 256
Dynamic Counter: Enable
R/w Queue Bypass:16
Bypass Max: 7
32 Byte Granularity: Disable
Time to test the stability of the ram; which is the reason for problems I had with stability. I run memtest in windows for 20mins without errors. [previously I got errors within a minute]. Then test 4M Super PI, which causes the program to not respond before, it passes the 32M test as well. Passed OCCT and all Video benchmark tests [Aquamark3, 3DMark03, 05, 06]. Primed 12.5hours.
STOCK Load Temps
CPU: 38-40
PWMIC: 38
Chipset: 46
STOCK Benchmark Scores
Aquamark: 76,003
3dmark03: 14,630
3dmark05: 6,762
3dmark06: 3,300
Sandra Memory: 5,781/5,719
Sandra CPU: 8,012/6,764
Everest read: 5,623
Everest write: 22,96
Everest latency: 46.8
OK, I have found good stable stock settings. Now I will start to find max mhz for the Opteron 148.
FINDING MAX CPU MHZ
I make a few changes to the stock settings in the bios. Changed LDT from 5 to 3; dram from 200mhz to 100mhz.
Start CPU-Z,ClockGen, SmartGuardian, task manager and OCCT. I keep an eye on temps with SG and overall mhz with CPU-Z, watch the 100% load on task manager, start OCCT test. Once I get a 100% load I start upping the FSB/HTT on Clockgen 10mhz at a time and wait for OCCT to not give me an error for at least 30secs. [I chose OCCT because it seems to fail more than superpi and also has a timer already counting for you]
FSB Listed passed at least 30secs of load unless noted:
210
220
230??? -restarted system [maybe it didnt like the big jump]
225,226,227,228,229
230,-239
240-249
[Temps still good, between 38-41 with load]
250-259
260,261
262=froze pc
Restart, Change bios FSB to 250; Boot into windows at 250x11 & Resume testing
Upped FSB to 261.87...fails OCCT...looks like max is 2872mhz @ 1.4v [261.1x11]
Restart, Set Bios to 261FSB & 1.425v
Load windows, set fsb to 262 and run OCCT
Passed: 262,263,264
Failed at 265
Bios: FSB 264 & 1.45v
Try 265 again...passes
266 fails
Bios: FSB 265 & 1.475v
Try 266 again...passes
267 fails
Bios: FSB 266 & 1.5v
Try 267 again...failed
I don't want to take it pas 1.5v because I will not run it daily that high. Temps are still decent around 40-43. As of now my max cpu mhz is roughly 2930mhz.
266x11 @ 1.5v*104%
Failed SuperPI 32M
265x11 @ 1.5*104%
Passed SuperPI 32M - 28:40
Passed OCCT
Passed Prime 8hr [large FF]
Benchmark Scores
Aquamark: 81,260
3dmark03: 14,993
3dmark05: 6,756
3dmark06: 3,479
MAX CPU MHZ = 265X11~2915MHZ
FINDING MAX RAM MHZ
Command Per Clock: Enable
Cas: 2.5
Trcd: 4
Tras: 8
Trp: 4
Trc: 7
Trfc: 13
Trrd: 2
Ter: 2
Twtr: 1~2
Trwt: 2~3
Tref: 3684
Twcl: 1
Dqs Skew Value: 0
Max Async Latency: 8ns
Read Preamble Time: 5ns
R/w Queue Bypass:16
Bypass Max: 7
Made a few changes in bios. Started CPU-Z and SG for monitoring, then ram memtest for a few mins. No errors yet. Up FSB up to 305 and I start getting errors. Since I don't plan to use DDR600 with my max cpu I figure max is somewhere between 300-305.
Passed: SuperPI32M, OCCT, 8hr Memtest
Failed Prime testing [blend test] @ 6hr 20min
Benchmark Scores
Aquamark: 75,293
3dmark03: 14,549
3dmark05: 6,757
3dmark06: 3,256
Didn't make my 8hr mark but I figure it's some little timing I'll have to fix, maybe not when I am shooting for 290FSB.
FINAL OVERCLOCK
Changed FSB to 290 and multi to 10x...gave dram a little more volts with 2.7v.
290x10 @ 1.5vcore
DDR590 2.5-4-4-8 @ 2.7vdimm
Quote:
FSB: 290
LDT: 3
Multi: 10
cpu vid: startup
cpu vid special: x110%
ldt : 1.2v
chipset: 1.5v
dram: 2.70v
dram +.03v: enable
Cas: 2.5
Trcd: 4
Tras: 8
Trp: 4
Trc: 7
Trfc: 13
Trrd: 2
Ter: 2
Twtr: 1
Trwt: 2
Tref: 3684
Twcl: 1
Dqs Skew Value: 0
R/w Queue Bypass:16
Bypass Max: 7
Passed SuperPI32M, OCCT, 3DMarks.
Failed Prime [blend] at 7hr8min
So close to my 8hr mark again...I figure the ram can handle the 290mhz so I tweaked the vcore. 1.4*110%.
Passed SuperPI32M, OCCT, 8hr Prime [blend]
FINAL Benchmark Scores
SuperPI32M: 25min 57sec
Aquamark: 88,843
3dmark03: 15,376
3dmark05: 6,917
3dmark06: 3,498
Sandra Memory: 7,616/7,610
Sandra CPU: 10,516/8,880
Everest Read: 7,521
Everest Write: 2,496
Everest latency: 39.5ns
EDITED
July 5 6:55am - updated stock benchmarks and prime length
July 5 6:15pm - updated full stock settings & added finding max cpu section
July 5 10:45pm - testing max stable cpu mhz [SuperPI 32M Passed] currently at 265x11 @ 1.5*104%
July 6 8:40am - updated end of max cpu mhz, found max cpu at 2915mhz
July 6 8:30pm - started max ram section...Testing DDR600
July 7 8:55am - Ram stable at DDR600 2.5-4-4-8 1T...prime test started
July 8 12:00pm - 8hr prime blend test failed at 7hr 8min. Lowered vcore to 1.4*110%. Currently doing superpi, occt, prime.
July 8 9:00pm - Found stable OC of 2900mhz DDR590 - Updated final benchmarks and final OC settings
Asylum
Joshzilla
PostPosted: Wed, 05 Jul 2006 14:46:06    Post Subject: Reply with quote View Single Post
Nice I'd like to see where this ends up. I got my opteron 148 up to 2.7Ghz stable and kinda gave up cuz it wouldn't do 3Ghz so i quit. Rolling Eyes
Modulok
PostPosted: Wed, 05 Jul 2006 14:55:47    Post Subject: Reply with quote View Single Post
Yeah, the ram should be able to do 300mhz, new bios has this cool thing where you can run ram mhz FASTER than the cpu mhz.
What are you at now with yours Asylum?
PostPosted: Wed, 05 Jul 2006 16:31:16    Post Subject: Reply with quote View Single Post
With my new ram I was able to get my Opt stable at 2800 (255 * 11).
I run it at 245*11 though Grin
Asylum
Joshzilla
PostPosted: Wed, 05 Jul 2006 16:50:12    Post Subject: Reply with quote View Single Post
I stuck it at 300*9 and gave up. I've been too busy lately to even mess with it.
Modulok
PostPosted: Wed, 05 Jul 2006 16:55:31    Post Subject: Reply with quote View Single Post
nice, that's also what I'm hoping to settle at..but 300x10 would be nice Grin
how many volts to your cpu?
PostPosted: Wed, 05 Jul 2006 17:28:47    Post Subject: Reply with quote View Single Post
Mine is all base, except for the ram. The ram is at 2.84, where suggested is 2.8, DFI expert put it at 2.64.
The ram is originally rated for 2.5-3-3-8, I took ram to 3-3-3-8 allowed me to get it up to 255 stable.
Asylum
Joshzilla
PostPosted: Wed, 05 Jul 2006 19:02:01    Post Subject: Reply with quote View Single Post
gonna have to look when I get home, it's been a while and I'm at work now.
Modulok
PostPosted: Wed, 05 Jul 2006 20:02:19    Post Subject: Reply with quote View Single Post
np asylum, I can wait Grin
Started to test max cpu...updated first thread with some stuff.
here is something for us to shoot for
Asylum
Joshzilla
PostPosted: Thu, 06 Jul 2006 00:21:52    Post Subject: Reply with quote View Single Post
CPU is stock @1.4V (1.37V actual)
NB 1.6V
RAM @ 2.8V
Running at 22C idle 30C load on water. Grin
Post new topic   Reply to topic    Bigbruin.com Forum Index -> Overclocking, Cooling, and Modding All times are GMT - 4 Hours
