Thermaltake 32GB DDR4-3200MHz WaterRAM RGB
kitguru.net
Post new topic   Reply to topic    Bigbruin.com Forum Index -> News
Ice Bank
Mice Elf
PostPosted: Tue, 08 Jan 2019 14:27:37    Post Subject: Thermaltake 32GB DDR4-3200MHz WaterRAM RGB Reply with quote View Single Post
Thermaltake has entered the DDR4 memory market in typical Thermaltake style. There are two kits of DDR4-3200MHz in the shape of a dual module 16GB kit and a quad module 32GB kit. You won’t be surprised to learn that WaterRAM comes with RGB lighting however the novel part is that these kits can be water cooled with the minimum of fuss. You have three distinct options when it comes to cooling; you can leave the modules bare, apart from their 2mm thick aluminium heat sinks that function through regular convection cooling. Alternatively you can top off the assembly with the water block with its copper base to increase the thermal mass and thus assist cooling. kitguru.net
boom!
Post new topic   Reply to topic    Bigbruin.com Forum Index -> News All times are GMT - 4 Hours
