Ice Bank Mice Elf
Posted: Wed, 09 Aug 2017 14:19:42 Post Subject: Ballistix Sport LT 16GB DDR4 SODIMM Memory Kit |
Besides the small performance bump in the encoding/rendering productivity applications, we have also seen lower loading times in various memory hungry games such as Forza after the upgrade and the stuttering was gone. One other aspect is that by using a larger memory quantity, we will also decrease the wear from the boot drive (a usage example would be working with a larger project in Adobe Premiere). Even if the RAM did run at the same frequency as before, the speed bump is mainly due to the switch from a single-channel (stock) configuration to a dual-channel. madshrimps.be _________________ boom! |
