Stealth Switch Desktop Cloaking Device
Post new topic   Reply to topic    Bigbruin.com Forum Index -> Miscellaneous
PostPosted: Sun, 05 Mar 2006 23:22:56    Post Subject: Stealth Switch Desktop Cloaking Device Reply with quote View Single Post
Maybe the boss walked by as you were playing Solitaire? Perhaps the wife came downstairs while you were visiting one of 'those' sites? A new product called the Stealth Switch may be the solution to discreetly cloak the contents of your PC desktop without raising any suspicion by those happening by. - The Review
Last edited by Doctor Feelgood on Fri, 28 Apr 2006 10:25:06; edited 1 time in total
Myself
PostPosted: Mon, 06 Mar 2006 13:38:12    Post Subject: Not the first desktop cloaking device Reply with quote View Single Post
The software GOTCHA! has offered a desktop cloaking feature for years. Gotcha is webcam motion detector software, whose main use is to create time-lapse movies or motion-triggered events. You can set it up with a camera pointing out your cubicle door, mask off an area so it doesn't notice you moving in your chair, and set the triggered event to be the minimization of one or more applications.
From http://www.gotchanow.com/text/g30f.html:
Quote:
Dying to play that video game, but you're at work? Use GOTCHA! to look over your shoulder for you. GOTCHA! will minimize your game and activate your work application in a second.
I don't work for, or know, the company. I've never even registered the copy I played with for a few days. But I knew of the product, and I knew it invalidated the Steath Switch's claim to be the "first" desktop cloaking device.
Post new topic   Reply to topic    Bigbruin.com Forum Index -> Miscellaneous All times are GMT - 4 Hours
