Joined: 07 Apr 2003 Posts: 17957 Location: New Jersey
Posted: Thu, 19 Jan 2006 11:26:05 Post Subject: |
You don't have enough coolers over there already?  _________________ Sometimes I laugh so hard that the tears run down my leg!
Hellfire Moderator
Posted: Thu, 19 Jan 2006 11:30:25 Post Subject: |
LOL not for VGA cards...only the Zalman one, which is on the 6600GT's in my second box. I've considered moving that, but then I'd have to mess with the RAM sinks, and don't want to pull those off the BFG since they are stuck on there almost
Usually don't care and deal with the default, but with eVGA the warranty is not voided when you put on a 3rd party HSF (as long as the HSF is designed for that chipset).
So if I can lower the card temp 10+ degrees over the stock 7800GT cooler, can't pass that opportunity up...not to mention the exhaust capabilities  |
scottyja Rated PG
Posted: Wed, 29 Mar 2006 11:05:36 Post Subject: An additional question to your review |
Hey, great review and tutorial for installing this thing. I'm picking one up for my video card, and I have a pretty stupid question... I'm hoping you can help me out!
The picture of the package contents (on the first page) shows a diamond shaped object (the back plate) and a black square shaped object (an insulator, I think). The question is about the black square piece. Where does this go? Between the back of the video card and the back plate? I'm kind of new to this and don't want to screw it up. At first I thought maybe between the GPU and the heatsink, but those are supposed to touch flush, right?
I guess I should just buy the card and the cooler and it may make more sense, but I'd like it to make more sense before I fork out the money! Thanks so much for any help! |
Hellfire Moderator
Asylum Joshzilla
Joined: 03 Feb 2005 Posts: 1142 Location: Suburbs of BFE
Posted: Wed, 29 Mar 2006 13:08:45 Post Subject: |
Thanks for the feedback Scottyja. Both Hellfire and Big Bruin are correct. The rubber disk fits between the metal backplate and the video card. There is actually has a smalled raised circle in the middle of the disk to help line it up with the back plate. Don't forget to use the rubber washers too!!!
 _________________ You can't drink all day unless you start in the morning. |
scottyja Rated PG
Posted: Wed, 29 Mar 2006 13:15:59 Post Subject: |
| Hey, thanks guys. I didn't even notice that peeking out the side. The install looks simple enough, but some of the reviews of the cooler said the instructions were pretty bad, so I appreciate your review! Wish me luck... |
scottyja Rated PG
Posted: Sun, 09 Apr 2006 15:38:50 Post Subject: |
| Dang! I'm installing as we speak and I'm applying the thermal paste and when I squeezed it out it got all on the side (the green board that the cpu is on, where you see the silver bumps). I got it off the best I could, but you can still see the residue... Am I hosed? Did I just toast this thing? |
Posted: Sun, 09 Apr 2006 23:10:30 Post Subject: |
Should be OK. Clean it up really good, and give it a shot. What type of paste is it? If it is the white kind, you are definitely fine... If it is some of the conductive (generally silver) kind, you need to be more careful! _________________ Sometimes I laugh so hard that the tears run down my leg!
scottyja Rated PG
Posted: Mon, 10 Apr 2006 10:57:42 Post Subject: |
Yeah, I think I'm safe. The package for my NV Silencer didn't have any paste which annoyed me, and I didn't want to have to deal with the place I ordered it from online (which would delay the install another couple of days), so I just broke down and paid double for the good (silver) stuff at Best Buy.
I cleaned it up with with some isopropyl and it cleaned off pretty well. When I booted it up, no sparks and no smoking... so hopefully I'm in the clear. Thanks for all your help! |
