Program to batch trim videos?
Ice Bank
Mice Elf
PostPosted: Wed, 01 Oct 2014 12:26:44    Post Subject: Program to batch trim videos? Reply with quote View Single Post
I have about 60 video clips that I would like to trim, and doing it one at a time would be a pain. Basically, just want a program that would accept all of them, let me tell it to trim the first xx seconds and the last yy seconds, and it will do its thing to all the movies at once.
Anything like that? Better yet - anything like that which is free? Cool
Thanks.
boom!
JimBowy
Moderator
PostPosted: Wed, 01 Oct 2014 14:14:36    Post Subject: Reply with quote View Single Post
take a look at FFMPEG. free and handles just about every batch command you could think of
- Jim
Ice Bank
Mice Elf
PostPosted: Wed, 01 Oct 2014 15:40:15    Post Subject: Reply with quote View Single Post
Thanks - is that easy to use? Is there a GUI? It looks like command line stuff from the examples I saw.
boom!
Ice Bank
Mice Elf
PostPosted: Wed, 01 Oct 2014 20:58:01    Post Subject: Reply with quote View Single Post
That seems complicated... Tried a few others, too... whoo, these are advanced!
boom!
Crisis
PostPosted: Fri, 24 Oct 2014 15:09:22    Post Subject: Reply with quote View Single Post
I don't know of one that can batch process, but you can try Avidemux. You'll manually select the area you want to keep then just export the media without re-encoding (choose copy for audio and video).
http://fixounet.free.fr/avidemux/index.html
You might also consider these two software, but I haven't tried them yet. They do support splitting video files
http://www.videohelp.com/tools/My-MP4Box-GUI
http://www.videohelp.com/tools/MKVtoolnix
