Lian Li Announces the PC-V1000L Full Tower Chassis
Versatile Tool-Less Features
~*77*~
Xenophobe
PostPosted: Tue, 02 Sep 2014 09:31:02    Post Subject: Lian Li Announces the PC-V1000L Full Tower Chassis Reply with quote View Single Post
High Airflow Full Tower with Versatile Tool-Less Features
September 2, 2014, Keelung, Taiwan - Lian-Li Industrial Co. Ltd today announces the PC-V1000L Special Edition full tower chassis. This brushed aluminum chassis features a ventilated front providing high airflow while featuring the high-end versatile tool-less designs for which Lian Li is known.
Short Full Tower with Full Hardware Support
With a height of only 551mm (21.7”), the 74L PC-V1000L can hold the hardware a PC enthusiast desires, including: motherboards up to EATX, the largest graphics cards, and extensive water cooling support.
Individually Removable Hard Drive Bays
DIY enthusiasts are able to individually mount/remove the 9 HDD bays according to their build preference. Each bay allows for a 3.5” or 2.5” drive to be tool-lessly mounted. For more storage potential one 3.5” drive or two 2.5” drives can be mounted behind the motherboard tray.
Extensive Cooling
Three 120mm fans pull cool air through the ventilated front panel. These front fans are attached to a removable bracket that slides out for easy maintenance.
At the bottom of the chassis a removable bracket secured by a single thumbscrew allows for two 120mm fans or a 240 radiator to be installed. At the top of the chassis a tool-lessly removable top panel allows for two 120mm/140mm fans or a 240/280mm radiator to be easily installed. A rear 120mm exhaust fan with two grommeted holes pulls hot air out of the chassis.
Wheels for Easy Maneuverability
The wheels design enables easy moving of a fully loaded system. A locking mechanism on the rear wheels prevents the chassis moving when set in place.
Connectivity
The I/O panel is located at the front of the chassis and contains 4 USB 3.0 ports and HD audio connections.
Price and Availability
The PC-V1000L will be available in black PC-V1000LA (Silver), PC-V1000LB (Black) and PC-V1000LWX (Internal Black with Window) in North America for the suggested retail price of USD 345 and USD 389 respectively.
More product information and pictures can be found here: http://www.lian-li.com/en/dt_portfolio/pc-v1000L/
Video overview: http://youtu.be/QgGLAtDABhM
Check out Lian Li's Facebook page here: http://www.facebook.com/LianLiHQ
About Lian Li
Lian Li Industrial Co. Ltd is an Aluminum Chassis and Chassis peripheral manufacturer and provider of industrial wholesale as well as OEM & ODM service for the PC industry as required. With over 20 years of service excellence, ISO 9001 certification and a team of professional staff willing to do the utmost to deliver durable, superior quality products, all backed by a *2 year guarantee; your satisfaction is guaranteed (*conditions apply). To learn more about Lian Li, please visit their websites at www.Lian-Li.com
