Will it fit? Biostar H81MHV3/CM Elite 110
Euro_Bucks
PostPosted: Sat, 23 Aug 2014 16:12:40    Post Subject: Will it fit? Biostar H81MHV3/CM Elite 110 Reply with quote View Single Post
Planning to build a budget system for my wife. It would be only used for gaming (Dota 2 to be specific). And i want it small.
Got a CM elite 110 already, just waiting the motherboard to arrive.
Will it fit?
Biostar H81MHV3
Support the Intel 4th generation Core i7 and Core i5 processors in the 1150 package
Intel H81 single chip architecture
Support 2-DIMM DDR3-1600/1333 up to 16G maximum capacity
Cooler Master Elite 110 ITX case
Thanks!
Ice Bank
Mice Elf
PostPosted: Sun, 31 Aug 2014 18:05:03    Post Subject: Reply with quote View Single Post
The Cooler Master Elite 110 ITX case is a Mini-ITX case - and that Biostar H81MHV3 is a Micro-ATX board. It will not fit (unless you have a big hammer)! You need a mATX case or larger for that motherboard... Or a Mini-ITX motherboard for that case.
boom!
