Joined: 07 Apr 2003 Posts: 18319 Location: New Jersey
Posted: Wed, 10 Nov 2004 07:34:46 Post Subject: Titan Siberia 12CM K8 CPU and System Cooler |
 | The Titan Siberia does its job, and then some! Not only does it cool your processor, but it also cools your system. Sporting a large fan (12cm), it keeps cool air flowing over everything, and definitely becomes a major centerpiece of your case, overshadowing your RAM and Northbridge. - The Review |
_________________ Sometimes I laugh so hard that the tears run down my leg!
Posted: Fri, 12 Nov 2004 00:14:20 Post Subject: |
This is one of the first reviews for the Siberia, and Titan appreciated the feedback, especially the CONS...
Due to manufacturing costs, packaging, etc they will only be offering blue fans, but like Hellfire says, you can get your own.
They didn't know what was meant by loose wires, so I explained that maybe some sort of mesh or sleeving will tidy it up... we'll see what they say on that.
And, the best news is that they are working on a fan controller that will fit any case. In addition to offering a PCI slot fan controller, the 3.5" bay controller will come with extenders to reach bolt holes mounted deeper into the drive bay... |
Posted: Fri, 12 Nov 2004 10:04:51 Post Subject: |
Very nice! The extenders would do the job perfectly!
Glad to have provided them some good feedback on it! |
