Planning to do side panel cutting.. (UPDATED)
UPDATE: Results Inside :D
lockhead
PostPosted: Fri, 22 May 2009 06:44:21    Post Subject: Planning to do side panel cutting.. (UPDATED) Reply with quote View Single Post
Quote:
Hey guys!
I'm planning to cut my side panel for my window kit I just ordered earlier by using a Dremel only. I checked in Gigabyte site and found out that the body material for my case is a 0.7mm SECC.
What type of cutting disc I will use for this one and what should be the rotation speed?
Thanks in advance. Smile
Here are the results
HARDCORE GAMER!
Intel Q9550 @ 4.0 Ghz with Noctua NH-U12P | ASUS P5Q Deluxe | 2 x 2GB OCZ Blade 1066 MHZ | 160GB Samsung | 500GB Maxtor | Corsair HX750W | LG Dual layer DVDRW | Diamond 4890 XOC | 20" Samsung 2043NWX | Scythe Kaze Master | Gigabyte Case
View user's profile Send private message Yahoo Messenger MSN Messenger
jedihobbit
PostPosted: Fri, 19 Jun 2009 16:04:28    Post Subject: Reply with quote View Single Post
What ever became of this? I'm not that diligent so couldn't tell you the rpm setting (believe between 7 - 10 for me) using the "standard" cutting discs. Try to get the 1-1/4 dia one though so they last a little longer.
As of 02/01/11
DreamCatcher AM3 >> (Down Again) >> SG01 Evo, MSI 785GM-E65, PII X4 955(AQ H2O Cooled), XFX GTX285(EK H2O Cooled), Seagate 7200.10 ST380815AS 80GB, 2 x G.S. F3-12800CL7D-2GBPI, MODU82+ EMD525AWT, XP Home SP2
KestrelFlight >> (Under Construction) >> Zalman Z7+, MSI NF980-G65, PII X4 1055T, 2 x Galaxy 580GTXs, Zalman 32GB SSD, WD V'Raptor 300GB, 2 x WD 1 TB Blacks, G.S. F3-16000CL9D-4GBTD, Zalman ZM1000-HP Plus , Win7
Oz1a v2.0 >> XFX MDA72P7509 750a, PI X2 8870BE, 2 x XFX GTS250, WD 250GB, F2-8500CL5D-2GBPK, Tt TR2 600W, XP Pro SP3
View user's profile Send private message MSN Messenger
lockhead
PostPosted: Thu, 02 Jul 2009 01:47:05    Post Subject: Reply with quote View Single Post
updates above Grin
HARDCORE GAMER!
fatbastard
PostPosted: Thu, 02 Jul 2009 08:15:58    Post Subject: Reply with quote View Single Post
Looks nice. Had I noticed this before I would have recommended the fiber reinforced cutting discs. They last longer and when they go they don't fly off into shrapnel.
flasher4q
PostPosted: Wed, 29 Jul 2009 13:58:58    Post Subject: Reply with quote View Single Post
very nice work on the window
jedihobbit
PostPosted: Wed, 29 Jul 2009 16:19:00    Post Subject: Reply with quote View Single Post
Yes...nice window with very nice internals!! Thumbs Up
As of 02/01/11
Blake
Unwillingly Unwitty
PostPosted: Wed, 29 Jul 2009 18:36:01    Post Subject: Reply with quote View Single Post
Looks great!! Wave
"I'm a mog: half man, half dog. I'm my own best friend!"
lockhead
PostPosted: Sat, 01 Aug 2009 08:03:16    Post Subject: Reply with quote View Single Post
thanks Grin
I updated my system. Changed the PSU and GPU to Corsair HX750 and Diamond Radeon 4890 XOC respectively. Did wire management too. Will post pics as soon as I get home.
EDIT: Changed the mems also to OCZ Blade DDR2 1066 Wink
HARDCORE GAMER!
Alex
PostPosted: Mon, 24 Aug 2009 11:52:26    Post Subject: Reply with quote View Single Post
Nice dremel work, I can never do the curved lines clean. Thankful my friend has a band saw =)
Post new topic   Reply to topic    Bigbruin.com Forum Index -> Mods and Ends All times are GMT - 4 Hours
