Joined: 07 Apr 2003 Posts: 18333 Location: New Jersey
MrPinKY Rated PG
Posted: Sun, 14 Oct 2007 11:40:07 Post Subject: western digital 250 gb review |
| I made the WD 250 GB substitution in my PS3 before reading this article, works fine, same result with some unusable space. My question: What did you do with the Seagate 60 GB drive removed from the PS3? I tried to use mine in an inexpensive external USB enclosure, but neither the PS3 or my laptop recognize it as a drive. Any advice would be appreciated. |
Modulok Rated XXX
Posted: Mon, 15 Oct 2007 09:09:27 Post Subject: |
You need to repartition and reformat the drive.
Assuming Windows XP: Right click "My Computer" choose Manage. On the left hand side, choose Disk Management. Locate your 60GB hard drive, and you should be able to repartition and format your new drive. FYI, you cannot use FAT32 over 30GB. I used Linux to format the entire drive with FAT32. (If you have Linux I recommend using FAT32 for portable storage.) |
MrPinKY Rated PG
Posted: Mon, 15 Oct 2007 11:07:05 Post Subject: |
| Many thanks, Modulok, this was exactly the information I needed. |
